Rutx11 to Rutx11 wifi network
Hello
i want to connect lan devices over a wifi network between two rutx11
what is the best option for do that
access point and cliient or mesh ?
regards
There are a few options:
You could either use mesh or Wi-Fi relay. In Your case, relay would be better as it is easier to set up and is made for smaller networks, unlike mesh, which is used on larger networks with more access points. Relay will extend the wireless network - one router will connect to another one’s Wireless network as a client and will relay all the requests. All the clients on both devices will be in the same subnet.
Here is a full instruction to configuring a Wi-Fi relay on a Teltonika router.
https://wiki.teltonika-networks.com/view/RUTOS_relay_/_Wi-Fi_extender_/_repeater_/_bridge_configuration
If you are interested to find out more about RutOS Mesh functionality and a tutorial on how to configure it yourself, you can read about it here:
https://wiki.teltonika-networks.com/view/Wireless_Mesh_configuration_example
If You have any questions, don’t hesitate to ask.
Julius
This topic was automatically closed after 12 days. New replies are no longer allowed.
