RUTX11 - Modem Update Crash
Hi.
I have a RUTX11 with Firmware RUTX_R_00.07.04.5.
Tried to update the internal modem, because it said that an update is available. It crashed several times using the FOTA in WebUI.
Then tried the way described here: RUTX Modem Firmware update process - #2 by ISMAILKISOUMI
First it looked good but suddenly nothing more happened and the update process stopped unecpected (aborted). Network access to the internet was permanent available.
Now the System says: “Internal modem is unreachable”.
Tried lsusb with the following result:
root@RUTX11:~# lsusb
Bus 003 Device 001: ID 1d6b:0002
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 003: ID 0a12:0001
Bus 001 Device 002: ID 05e3:0610
Bus 004 Device 001: ID 1d6b:0003
Bus 002 Device 001: ID 1d6b:0003
Bus 003 Device 014: ID 05c6:9008
seems that the the modem is in emergency download mode (see: RUTX11 internal modem unreachable - #5 by Daumantas)
I really do not now what to do now.
Any ideas?
Solved it by myself by forcing a modem upgrade (please see):
modem_updater -f -v EG06ELAR04A20M4G -i 3-1 -n 0 -d Quectel
