RUTX11: How to get GPS coordinates when using remote ssh connection to router?
GPS related questions:
My RUTX11 router web UI says that Status / Service / GPS
Enabled = On
Status = Up
How can I get GPS coordinates from RUTX11 when using remote ssh connection to router?
Do I need to install additional packages or is the GPS support available in the default config?
What commands to use to install / to get the coordinates?
Thank you for your support and help!
From a ssh console: gpsctl -ixa for latitude longitude altitude, gpsctl -h for help.
gpsctl is installed by default.
Seems to work fine! Thank you!!
