RUTX11 failing to connect with Things Mobile SIM
This is the situation at the moment:
  • SIM card works fine in my phone with no custom settings required.
  • When inserted into router sim is indicated as active, router reads it’s details properly. Signal strength is good (-77), auto APN fails, manual APN ( TM ) seems to succeed, but it gets stuck at assigning an operator.
  • Manually searching for and selecting operators doesn’t work - it identifies operators, but connecting to them doesn’t work
  • Tried both sim card slots
  • Tried various APN’s: TM, tm, pepper, iot.tm, mobile.tm
I’ve sent you a form to fill out so we can continue our conversation in private, to avoid accidentally leaking any sensitive information. In the Ticket ID field, simply enter the thread’s number, which is 14560.
This particular device will require an RMA procedure, as after analyzing the situation, it looks like the mobile modem is not functioning properly.
