RUTX11 cell lock and carrier aggregation problem
Hello all!
I need your help on annoying behaviour with a RUTX11 (Firmware version RUTX_R_00.07.07.1 , Internal modem firmware version EG06ELAR04A20M4G )
If there’s no active cell lock (I mean, after issuing in CLI
gsmctl -A 'AT+QCFG="NWSCANMODE",3,1'
gsmctl -I
gsmctl -A 'AT+QNWLOCK="common/lte",0'
) then carrier aggregation works but it often doesn’t pick the best cellID (either as primary or as aggregated one).
On the contrary, If I force the modem to lock onto the best signal cell (I mean issueing in CLI
gsmctl -I
gsmctl -A 'AT+QNWLOCK="common/lte",2,*EARFCN*,*PCI*'
) then it will stuck on that CellID but it won’t aggregate other carrier anymore.
just as an example of sub optimal carrier selection
Given this scenario
root@RUTX11:~# gsmctl -I
"neighbourcell intra","LTE",1850,306,-10,-79,-50,0,-,-,-,-,-
"neighbourcell intra","LTE",1850,407,-20,-92,-63,0,-,-,-,-,-
"neighbourcell intra","LTE",1850,286,-19,-89,-63,0,-,-,-,-,-
"neighbourcell intra","LTE",1850,434,-20,-91,-61,0,-,-,-,-,-
"neighbourcell inter","LTE",3025,247,-19,-102,-75,0,-,-,-,-
"neighbourcell inter","LTE",3025,312,-9,-95,-76,0,-,-,-,-
"neighbourcell inter","LTE",3025,246,-8,-91,-75,0,-,-,-,-
the modem hook the worst B7 (with obvious drawbacks) even restarting the connection.
What’s wrong? How can I solve this problem (if I can)?
TIA you all.
