RUTX11 - Cannot enable network share
In the menu “Services/SD & USB Tools” I cannot see the Network Shares to configure the USB MSD. Only the general menu is visible The USB is mounted and I can see it in the configuration.
The last firmware is installed
The problem is solved, I had to install the network package first.
Hello @jukiwuki,
Good to hear that you’ve found a solution!
Please feel free to reach out on the forum if you need any further assistance.
