Hello everyone.
I have an issue with Starlink when using WAN and the RUTX11 router. The modem and router are fully updated. I set up a 70/30 split with a SIM card in slot 1, but the SIM card still takes priority and handles most of the traffic, while Starlink keeps turning on and off. How can I properly configure the load balancing so that Starlink remains the primary connection and the SIM card is only used as backup?
Could you confirm if there’s still an issue configuring your desired setup with the latest 7.13.3 firmware? From your description, it seems you want Starlink WAN to be the primary connection, with the SIM card used as a backup when Starlink loses connectivity.
If this is the case, the Failover feature, rather than load balancing, would be the correct solution. This ensures that if Starlink fails or loses its connection, the mobile WAN interface will automatically take over as the backup. Keep in mind that either Failover or Load Balancing can be used depending on your specific needs.
More detailed information and the differences between these features can be found here.
If you need further assistance, please provide more information regarding your desired use case or scenario.
