RUTX11 07.11.3 wireguard endpoint host
The “Endpoint host” field in the peer configuration section appears to be mandatory even if the router is not the initiator of the tunnel.
One has to put something in the field which can be resolved (an IPv6 address for example) in order to be able to save the config. And then the router will try to send data packets to this bogus destination of course no reply will ever be received…
Workaround: enter something then manually delete the “option endpoint_host” line from /etc/config/network, and restart the network layer.
This seems to be fixed in version 07.12
I’m glad to hear the issue is resolved!
Please don’t hesitate to reach out if you need any further assistance regarding this topic.
