On a RUTX10 (HW revision 0013, bootloader 3.3), I upgraded from RUTX_R_00.07.23.7 to RUTX_R_00.07.26.1 using the WebUI (System → Firmware, keep settings). The device rebooted, and the event log says:
“Firmware RUTX_R_00.07.23.7 successfully upgraded to RUTX_R_00.07.26.1”
But the device was still running 07.23.7, even after a second manual reboot.
What I checked over SSH (read-only):
/etc/version and ubus call system board both reported 07.23.7.
The inactive firmware bank (rootfs_1) did not contain the new image, and /proc/boot_info/rootfs/primaryboot did not change. The image was never written.
The “successfully upgraded” event is logged during boot, before “Device startup completed”. It does not seem to check the firmware that is actually running.
Workaround: upgrading to RUTX_R_00.07.26 (07.26.0) from the same WebUI worked at the first attempt. The bootloader went from 3.3 to 2.28.0. Then 07.26.0 → 07.26.1 worked at the first attempt, on this device (bootloader 2.28.0 → 2.28.1) and on another device.
The same thing had already happened on this device in June: two “07.23.5 → 07.23.7” events 5 minutes apart, and only the second attempt was applied.
Questions:
Is 07.26.0 a required intermediate step before 07.26.1 when coming from 07.23.x, for example because of the bootloader update? If so, could it be stated in the release notes?
Could the WebUI show an error when the image is not flashed, instead of logging a successful upgrade?
We deploy RUTX10 and RUTM10 routers in a fleet of mobile robots. We would need direct access to Teltonika support to create tickets for this kind of issue. Who should we contact to set this up?
@ewaldner, I tested the RUTX10 upgrade and was unable to reproduce the behavior you described. Could you please confirm whether any other routers in your fleet reported a successful upgrade but continued to run the previous firmware after reboot?
The RUTX10 supports a direct upgrade from 07.23.7 to 07.26.1 without first installing 07.26.0. Version 07.26.1 has passed internal testing and is designated as Latest firmware. We recommend testing it on a small number of devices before updating the rest of your fleet.
For HelpDesk access, please contact your Teltonika Networks sales manager. If you purchased your devices through a distributor, please reach out to them.
@rmelior, has your TRB140 continued to operate normally since the upgrade, or have you noticed any other unexpected behavior? A single retry does not establish whether flash memory wear contributed to the issue. Have any previous upgrades on this unit or another TRB140 also required a second attempt?
