Rutx10 temperature over Mqtt
Does Rutx10 (Product code:RUTX1000XXXX) have internal temperature sensor?
I can get id, name or uptime value over mqtt publisher, but then ask get temperature, I get n/a.
https://wiki.teltonika-networks.com/view/Monitoring_via_MQTT
Where are all possible mqtt topics for rutx10?
If all data can be read through MQTT except for the temperature, it’s likely a problem with the temperature sensor. To verify this, you can use alternative monitoring options, which actually offer more parameters than MQTT. Check out these links for more details: Monitoring via Modbus (RUTX10 Monitoring via Modbus - Teltonika Networks Wiki) and SNMP (RUTX10 SNMP - Teltonika Networks Wiki). By trying these, you can determine whether the temperature sensor is faulty or if the issue lies with MQTT.
Marijus
So then what is modbus TCP address for temperature? Not listed in wiki.
to clarify commands on MQTT side router answer to temperature request, but data is invalid
I may have overlooked that you mentioned the RUTX10 model. Typically, temperature in routers is monitored in modems. In this case, the RUTX10 doesn’t have a modem, resulting in an “n/a” reading.
Marijus
