Dear Customer Support,
after upgrading firmware to 7.04.4, I’m not anymore able to connect via modem.
I have tried to downgrade firmware to 7.01.4 via webUI but this doesn’t solve the problem.
3G and 4G led are blinking in sequence.
In the system log file, downloaded through the System>Administration menu, I can see the lines below.
(It seems I’m not permitted to attach files to this post).
My modem is identified by the following FW version: EG06ELAR03A05M4G
Is there anything I could try to recover?
Luca
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: gsm send: AT+CGATT?
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: gsm get: +CGATT: 0
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: Module not attached…Can’t get IP. Changing APN…
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: gsm send: AT+QCFG=“IMS”
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: gsm get: +QCFG: "ims",2,0
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: VoLTE should be off
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: gsm send: AT+CGDCONT?
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: gsm get: +CGDCONT: 1,"IP","iliad","0.0.0.0",0,0,0,0 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 10,"IP","","0.0.0.0",0,0,0,0 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 11,"IP","","0.0.0.0",0,0,0,0 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 12,"IP","","0.0.0.0",0,0,0,0 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 13,"IP","","0.0.0.0",0,0,0,0 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 14,"IP","","0.0.0.0",0,0,0,0 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 15,"IP","","0.0.0.0",0,0,0,0 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 16,"IP","","0.0.0.0",0,0,0,0 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 3,"IPV4V6","sos","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,1 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 4,"IP","","0.0.0.0",0,0,0,0 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 5,"IP","","0.0.0.0",0,0,0,0 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 6,"IP","","0.0.0.0",0,0,0,0 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 7,"IP","","0.0.0.0",0,0,0,0 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 8,"IP","","0.0.0.0",0,0,0,0 Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: +CGDCONT: 9,"IP","","0.0.0.0",0,0,0,0
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: PDP Type MATCH
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: gsm send: AT+QICSGP=1
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: gsm get: +QICSGP: 1,"iliad","","",0
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: gsm send: AT+CFUN?
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: gsm get: +CFUN: 1
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: gsm send: AT+CFUN=4
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: gsm get: OK
Mon Jul 24 09:48:26 2023 daemon.info unhandler[2447]: gsm send: AT+QICSGPEH=1
Mon Jul 24 09:48:27 2023 daemon.info unhandler[2447]: gsm get: ERROR
Mon Jul 24 09:48:27 2023 daemon.info unhandler[2447]: gsm send: AT+QICSGP=1,1,“”,“”,“”,0
Mon Jul 24 09:48:27 2023 daemon.info unhandler[2447]: gsm get: OK
Mon Jul 24 09:48:27 2023 daemon.info unhandler[2447]: gsm send: AT+CFUN?
Mon Jul 24 09:48:27 2023 daemon.info unhandler[2447]: gsm get: +CFUN: 4
Mon Jul 24 09:48:27 2023 daemon.info unhandler[2447]: gsm send: AT+CFUN=1
Mon Jul 24 09:48:29 2023 daemon.info unhandler[2447]: gsm get: OK
Mon Jul 24 09:48:29 2023 daemon.info unhandler[2447]: gsm send: AT+CGPADDR=1
Mon Jul 24 09:48:29 2023 daemon.info unhandler[2447]: gsm get: +CGPADDR: 1,""
Mon Jul 24 09:48:31 2023 daemon.info unhandler[2447]: gsm send: AT+CGPADDR=1
Mon Jul 24 09:48:31 2023 daemon.info unhandler[2447]: gsm get: +CGPADDR: 1,""
Mon Jul 24 09:48:33 2023 daemon.info unhandler[2447]: gsm send: AT+CGPADDR=1
Mon Jul 24 09:48:33 2023 daemon.info unhandler[2447]: gsm get: +CGPADDR: 1,""
Mon Jul 24 09:48:35 2023 daemon.info unhandler[2447]: gsm send: AT+CGATT?
Mon Jul 24 09:48:35 2023 daemon.info unhandler[2447]: gsm get: +CGATT: 0
Mon Jul 24 09:48:35 2023 daemon.info unhandler[2447]: Module not attached…Can’t get IP. Changing APN…
Mon Jul 24 09:48:35 2023 daemon.info unhandler[2447]: Connection failed. Another attempt after 1800 seconds
