Rutx09 Bridge LAN
Please help me with the rutx9 router, is it possible to separate Lan ports 1/2/3, i.e. isolate them from the default Lan bridge. So that each port is individually configured as in the case of port 4. I am trying to replace the netmodule NB1601 router, there is such an option in the configuration menu, in Rut I do not even see such an option.
Regards, Łukasz
To separate LAN ports, you can create a separate VLAN for each LAN port and assign each VLAN to a different firewall zone.
Here are some wiki examples that should be helpful:
Please let me know if you still need assistance!
