RUTX_R_00.07.05.3 Failover Behaviour Change?
Hi all,
Has failover behaviour changed in a recent update? We’re noticing that connections do not flush correctly since upgrading to RUTX_R_00.07.05.3 - also that when in failover mode with load balancing over 2 links, one remains in standby instead of both being active. Tested with 2 separate RUTX12 units.
Group 1: WAN (primary active), flush on connect/disconnect
Group 2: MOB1 + MOB2, 1:1, flush on disconnect
After rolling back to version 7.04.5 everything seems to work as expected.
Hello Stinkys
Kindly Provide us the troubleshoot file for a better understanding of the cause of trouble
We will be looking into it
