Please, how can I lock some internet site (games site for example) by RUTX11 for only two pc on the lan, without using Microsoft account ?
Thank you all
Regards
Thank you for your inquiry. Could you please clarify what you are trying to achieve? By “locking” the site, do you mean blocking access to those websites for the two specific LAN devices, or do you intend to prioritize or manage traffic for those sites?
- For blocking websites:
Best option would be using the Web Filter function, which allows you to block access to specific domains or content categories. More details can be found here: RUTX11 Web Filter - For prioritizing traffic:
If your goal is to manage or prioritize traffic to those sites, you should use the QoS feature. More information on how to configure QoS can be found here: RUTX11 QoS
Please let me know which option suits your needs, or if you require further assistance.
Hello again Martynas,
Yes, I mean blocking access to those websites for the two specific LAN devices.
These two devices are two pc with a specif IP
Is it possible by my rutx11 ?
Thank you very much
Best regards
If these two PCs are the only devices on the LAN, then using the Web Filter would be a sufficient method to block their access to the desired hostnames. However, please note that if “All LAN interfaces” is selected in Network field, the restriction will apply to all LAN devices, not just the two specific PCs.
If you need to block traffic only for these two specific LAN IPs, you can achieve this using Traffic Rules, but you will need to specify the hostname IP addresses manually.
I hope this helps! Let me know if you need further assistance.
