RUTX 10 Security
Hello community,
I would like to implement all attack prevention on our Rutx10 fw.
I’m trying to find a good standard value (initial value) for limit/Limit Burst while trying not to block production
I’m talking about: Remote ICMP Req, SSH Attack Prev, HTTPs Attack Prevention and port Scan.
Thank you
Max
There is a section in the WebUI under Firewall called ‘Attack Prevention.’ The Attack Prevention menu tab allows you to configure protections against certain types of online attacks. I recommend checking it out. More information can be found on our wiki page.
Hope this helps!
i know there is a section in webui → Attack prevention (I’m asking for this very reason) and i know about wiki.( and i know netfilter / iptables)
Standard value on wiki for Remote ICMP Req is 5 - 10
In wiki there is value ( limit and limit burst) with " default: none" ( SSH Attack Prev, HTTPs Attack Prevention and port Scan.)
What value do you recommend I start with?
Best regards
m.
Sorry for any inconvenience. Here are the recommended starting values for limit and limit-burst settings for SSH Attack Prevention, HTTPS Attack Prevention, and Port Scan Prevention (The ICMP recommendation is the same as in the wiki):
  1. SSH Attack Prevention
    Limit: 5
    Limit Burst: 10
  2. HTTPS Attack Prevention
    Limit: 20
    Limit Burst: 40
  3. Port Scan Prevention
    Limit: 5
    Limit Burst: 10
Nice,
Thanks!
You are welcome!
Please let me know if you have more questions or require further assistance.
