Rutm51 Disconnects multiple times a day
Hi!
My RUTM51 disconnects multiple times a day. And it wont come up until reboot
Here is some log.
Newest firmware is installed and settings is reset also.
Its been doing this from the begin, Few firmware ago it was viable to use becouse auto reboot, but now the problem is getting worse and auto reboot wont help
3868
2025-06-30 13:46:57
Health checker
Network
Notice
IPv4 connectivity started to fail
3869
2025-06-30 13:47:06
Health checker
Network
Notice
IPv6 connectivity started to fail
3870
2025-06-30 13:47:09
Switch Events
Network
Notice
Port link state of port LAN2 changed to DOWN
3871
2025-06-30 13:47:12
Switch Events
Network
Notice
Port link state of port LAN2 (1000 baseT) changed to UP
3872
2025-06-30 13:47:12
Switch Events
Network
Notice
Port speed for port LAN2 changed from 10 baseT to 1000 baseT
3873
2025-06-30 13:47:21
Switch Events
Network
Notice
3874
2025-06-30 13:47:23
Switch Events
Network
Notice
Thank you for reaching out. In this case, to assist you effectively, we’ll need to continue this process privately, because sensitive/publicly unsharable information needs to be gathered. You should find a support request form in the inbox of the email address you used for your forum registration. Kindly fill out the form, and please reference Ticket ID: 14450 when submitting it. Once the form is completed, we’ll contact you directly via email to investigate the issue in detail and help work towards a solution.
I didnt get any email which contains any kind a form? Not even in junkmail.
Or am I just blind :slight_smile:
Only your forum answer above is in my email
Hello @Slazha,
The form was resent. Could you check your inbox once again (including spam/junk boxes)?
