RUTM10 bug that halts it
Repeated the bug twice. I did only two modifications to default RUTM10: I have ping reboot to IP and DNS. When Tailscale is only as exit-node it works, but when activating ‘accept routes’ the RUTM10 halts and does not respond to anything. WiFi dissappers. Only factory reset helps.
Could you please specify the firmware version currently installed on your device?
If it’s not the latest version (7.13.4), please download it from the following link and update your device: https://wiki.teltonika-networks.com/view/RUTM10_Firmware_Downloads.
If the issue persists after updating to the latest firmware, please provide more information about both your Auto Reboot and Tailscale configurations. It would also be helpful if you could include screenshots.
