RutM08 for seperation of network
I have an industrial machine where I am experiencing network issues. When the machine is running, the PROFINET communication is sometimes lost.
In the network, there is PROFINET traffic as well as regular traffic for a vision camera and a robot.
From a previous discussion, I was advised to use a router. I now have a RUTM08, but I cannot find the correct settings to configure the network as I want.
My goal is:
  • One network for remote service access (this network should be able to communicate with all other networks)
  • A second network dedicated to PROFINET
  • A third network for normal traffic
Can someone help me with this?
Gerard
Could you please clarify the following point?
How is the Remote Service Access network intended to be established? Will it be connected through the WAN interface, a VPN tunnel, or RMS?
Additionally, could you share your current IP addressing scheme and, if possible, a simple network topology sketch showing the desired setup?
For VLAN configuration, you can follow the instructions here: VLAN Set Up - Teltonika Networks Wiki
Using VLANs, you can separate the physical ports into different networks. For example:
LAN1 → 192.168.1.1/24
LAN2 → 192.168.2.1/24
LAN3 → 192.168.3.1/24
You can then create separate firewall zones for each network under Network → Firewall → Zones . For example for normal traffic you can use the default LAN zone and create 2 new ones for remote and profinet.
The forwarding rules could be configured as follows:
Allow Forwarding from WAN/VPN to LAN (so remote service can reach cameras/robots)
Allow Forwarding from WAN/VPN to PROFINET (so remote service can reach PLCs)
Reject/Deny Forwarding between LAN and PROFINET
