Hello. I'm in Portugal and my RUTC50 with an O2 data SIM is recognized and everything works fine.
However, when I start a TV app like WaipuTV, there's no data stream.
Hallo. Bin in Portugal mein RUTC50 mit einer Daten SIM von O2 wird erkannt und alles läuft so weit.
Nur wenn eine TV-App wie WaipuTV starte, kommt kein Datenstream.
WaipuTV probably is georestricted, due to programme licensing agreements. Access it in Germany no problem but if outside of Germany, and if WaipuTV is georestricted, it won’t stream.
Nein es unterliegt keinen Einschränkungen, es sind alle Apps betroffen die auf dem Tv gestartet werden können.
Mit einer Portugiesischen Datenkarte ist alles einwandfrei, nur die deutsche Simkarte gehen nicht und diese sind auch ohne Einschränkung. Nur YouTube läuft mit der O2 Karte genauso die Apps vom Amazon Stick
If possible, let’s continue our communication in English so nothing is lost in translation.
Could you please clarify what exactly isn’t working?
Do I understand correctly that the SIM card is providing internet to all devices, but only the TV is experiencing issues, specifically, that YouTube works while other apps on the TV do not have internet access?
Yes, that’s right. It’s not the TV. I have two of them and both have the same problem. O2 Online is also stumped and suspects it might be the location.
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 16790.
