I recently noticed that the RUTC50 device does NOT keep any settings during a firmware update over the air (FOTA). Instead the device is set to factory default(s). This is some kind of annoying because I’ve to reconfigure the device onsite. RMS access for reconfiguration isn’t possible until I’ve set up the configuration of RUTC50 again manually.
This is a really bad behaviour if the device has to be remote managed and / or upgraded remotely. Is the product support aware of this (intended?) forced cleanup by a factory reset after a firmware update has happened?
I do also have SME enabled (see above). The USB storage drive had to be reformatted after the firmware update has taken place and enabled (sync write on).
Our development department is already aware of this issue and we will inform you as soon as we receive a response from them. Thank you for your understanding and patience.
