RUT9xx Traffic Logging
Hello
Since the update to Version RUT9_R_00.07.06.16 I get blank traffic log, the ulogs_wifi.log has a size of 0KB. Before the update it worked perferct.
I’m using the “Traffic logging” package and when I open the Traffic Logging settings page I get the error message that it failed to load the network options. As well I can not select any network.
On the page System → Maintenance → Traffic Log I still can see some traffic logs, but it would be nice to have them in a file to analyze.
Any Idea what I have to change that it will work again? Thank you very much for your help.
Thank you for your reaching out.
I have tested the traffic logging service on the RUT9_R_00.07.06.16 firmware and can confirm that it works when the package is uploaded manually via the WebUI. To resolve the issue, you’ll need to manually remove the Traffic Logging package via System → Package Manager → Packages page, or you can factory reset the device.
After that, you will need to download the Traffic Logging package from this link: Download Traffic Logging Package
Then, upload the package manually via System → Package Manager → Upload page. Click Browse next to the Upload package field and upload the traffic_logging.tar.gz file.
I hope this helps! If you need further assistance or have any additional questions, feel free to reach out.
Thank you for your reply.
I tried deleting and reinstalling the package, unfortunately it did not work.
After resetting my router and doing a new configuration step by step, I realized that the traffic logging stopped working as soon as I set up a second LAN interface for the guest network.
Any idea why?
Did you hade a change to try it with a second LAN interface?
