RUT956 with USB WiFi Adapter
Hi, I have a problem with a client site where I am using RUT956 in WiFi client mode. The site has upgraded its network to WiFi 5 standard, and are only using 5GHz radio channel. As the RUT956 is only Wifi 4 standard, 2.4GHz radio channels, I can no longer connect to the site network. There is also no GSM signal in the location so WiFi is the only network connection option.
One solution is to use an external USB AX1800 dual band Wireless network adapter to connect via the 5GHz radio channels.
Does anyone know if this is possible, and can the RUT956 connect via an external WiFi adapter ?.
