RUT956: PORT LINK STATE OF PORT LAN1 CHANGED TO UP/DOWN
Hello, I have checked the forum for similar questions, but no solutions were found for this problem. Has anyone discovered a solution?
The RUT956 has a 4G modem connection only, and both ports are switched as LAN interfaces. The modem sometimes disconnects from the mobile network every hour. At times, it stops working very often and only comes back after the electricity is turned off and on again.
The log shows that port states switch between UP and DOWN constantly.
ID Date Event Type Event
6603 2023-12-14 08:15:13 Switch Events Port speed for port LAN2 changed to 100 baseT
6602 2023-12-14 08:15:13 Switch Events Port link state of port LAN2 changed to UP
6601 2023-12-14 08:15:10 Switch Events Port link state of port LAN2 changed to DOWN
6600 2023-12-14 08:15:08 Switch Events Port speed for port LAN2 changed to 100 baseT
6599 2023-12-14 08:15:08 Switch Events Port link state of port LAN2 changed to UP
6598 2023-12-14 08:15:08 DHCP Leased 192.168.1.225 IP address for client [redacted] - AMBUGUA-ENG in LAN
6597 2023-12-14 08:15:05 Switch Events Port link state of port LAN2 changed to DOWN
6596 2023-12-14 07:26:03 Network Operator Connected to SAF FOR YOU Safaricom operator (internal modem)
6595 2023-12-14 07:26:03 Network Type Joined LTE network (internal modem)
6594 2023-12-14 07:26:03 Mobile Data Mobile data connected (internal modem)
6593 2023-12-14 07:25:30 Network Operator Connected to SAF FOR YOU Safaricom operator (internal modem)
6592 2023-12-14 07:25:30 Network Type Joined LTE network (internal modem)
6591 2023-12-14 07:25:30 Mobile Data Mobile data connected (internal modem)
6580 2023-12-13 12:55:08 Switch Events Port link state of port LAN2 changed to DOWN
6590 2023-12-13 12:50:07 DHCP Leased 192.168.1.225 IP address for client [redacted] - AMBUGUA-ENG in LAN
6589 2023-12-13 12:50:06 Switch Events Port speed for port CPU/WiFi changed to 1000 baseT
6588 2023-12-13 12:50:06 Switch Events Port link state of port CPU/WiFi changed to UP
6587 2023-12-13 12:50:06 Switch Events Port speed for port LAN2 changed to 100 baseT
6586 2023-12-13 12:50:06 Switch Events Port link state of port LAN2 changed to UP
6585 2023-12-13 12:46:16 DHCP Leased 192.168.1.225 IP address for client [redacted] - AMBUGUA-ENG in LAN
6584 2023-12-13 12:46:05 Switch Events Port speed for port CPU/WiFi changed to 1000 baseT
6583 2023-12-13 12:46:05 Switch Events Port link state of port CPU/WiFi changed to UP
6582 2023-12-13 12:46:05 Switch Events Port speed for port LAN2 changed to 100 baseT
6581 2023-12-13 12:46:05 Switch Events Port link state of port LAN2 changed to UP
6579 2023-12-13 12:44:52 DHCP Leased 192.168.1.109 IP address for client [redacted] - NDERITU-MAINTENANCE in LAN
We have a number of RUTX devices where we also get the same thing. Ports going up/down until the router hangs. We’ve found no issue upon inspecting the cables, so I’ve wondering if it could be the router.
Welcome to Teltonika Networks Community !
There are a few points that you can check to better understand the root cause.
  1. Please check if you are updated to the latest FW as we have improvements for Mobile Connection present
  2. You can check the System Logs to confirm why it is getting disconnected, It can just be the ISP DHCP renewal.
    3.Please check for the Mobile signal parameters and compare it with https://wiki.teltonika-networks.com/view/Mobile_Signal_Strength_Recommendations , especially the SINR value.
    The LAN port link state is just the auto negotiation between the router and the connected LAN device and should not disrupt the mobile connectivity.
    Clive Pinto
