Hi everyone
We are using MQTT and I/O juggler to send messages to a Mosquitto broker and have come across a couple of issues we can’t find answers for and was hoping someone may help.
Firstly is there a way to send the value of Digital Input 1 in a Boolean format and not the Open/Shorted string that the %g3 gives us.
Secondly is there a way to send the value via MQTT every 5 minutes and not necessarily on change of state. We can see that it might have to be via a custom script in CLI and crontab but have no experience in that field and may need an example. It would be nice to have a interval based trigger in the I/O juggler.
Thanks in advance
Matthew
Hi tri,
Have you tried using Data Type: 16 bit UINT, high byte first? This will give you boolean values of 0 (low) or 1 (high).
We have a feature called Data to Server, wherein you can send this data via MQTT in a given interval. Please refer to this link as a guide.
Let me know if this helps.
Janmiguel
Thanks for looking at this for me.
I have setup the Modbus server and client, as you suggested, and am reading this as a true Boolean point eg. 1 or 0
The issue is sending just that value via the Data to Server function to our MQTT broker. Despite trying to find an example that makes sense to me, I am only receiving a string value at the Broker which looks like { “input1”: “0” } when using custom format in the request. I do not want to send JSON just the pure value. If you have a working example that would be very helpful
Regards
Matthew
Additional configuration must be done in data to server side. Click on the collection configuration and change format type to Custom as shown below. You can remove the quotation marks if it works better for you.
