RUT956 - MQTT bridge issue with the firmware "RUTM9M_R_00.07.11.3"
After an update of RUT956 with the version (RUTM9M_R_00.07.11.3) and a reboot, I have a lot of problem with all MQTT connections by bridges.
2 bridges are configured for a redondancy connection (one per broker).
The “local MQTT Broker (Mosquitto)” on RUT956 work correctly with all devices, but half data are “bridged” to “distant MQTT Broker (Mosquitto)”.
Expecially RUT956 datas from the service “Data to Server”.
Thank you in advance for your support
Thank you for reaching out.
To effectively troubleshoot the MQTT bridge problem and gather more details, I’ve sent you a form to fill out.
For the ticket ID, please use “11595”. Once the form is submitted, we’ll contact you privately to investigate the issue further.
