RUT956 - Modbus Serial Client sending data using Data to Server via MQTT
I am trying to collect data from an equipment using Modbus Serial Client via RS485. I can collect the data from the Client, the problem is that I cannot see any way forward to send the polled data to the Data to Server (MQTT) in the configuration page. I can do a Modbus TCP → Data to Server (MQTT) because there is an option to only use TCP but I cannot pick up the Serial data. How do I get the Serial data to the Data to Server Module?
