What is the recommended way to configure a RUT956 so that devices on the LAN have internet access via a Wi‑Fi WAN (client) connection to an office Wi‑Fi access point?
I have already connected the RUT956 to the AP and created a WAN interface. I also configured relayd to map the LAN to the WAN interface; however, I am still unable to get internet access working on the LAN side. Any support would be great. Thanks
If you need the end devices to receive IP addresses directly from the office access point, then using relayd is the correct approach. In that case, I recommend following this configuration example: Relayd RutOS - Teltonika Networks Wiki
Please let me know the results once you have tried this. If you encounter any issues, kindly provide screenshots of your configuration so I can review them.
Thanks for the update, I managed to resolve the issue. I had to use the relayd function to ensure the data route connected the WifiLAN instance to the LAN Wired Connection.
Thanks again for your reply and support. Have a great day.
