RUT956 FW7.14.2 Device Name UNKNOWN
I have a RUT956 device that after firmware update the device name is UNKNOWN.
The Overview Page is blank and a second update of the Firmware dosnt make any changes
How can it be solved?
Thank you
Good afternoon,
In your case, If you could try attempting a bootloader reset. Instructions : RUT956 Device Recovery Options - Teltonika Networks Wiki
Firmware : RUT956 Firmware Downloads - Teltonika Networks Wiki
Don’t forget after the reset, before accessing the device, remove static IP from your PC network.
Arturas
His device lost manufacturing info @anon46660955
FW update through bootloader will not help :slight_smile: You need to arrange the remote session and recover.
Yes, it didnt work with the bootloader reset. Same Thing after that.
I have sent you a form for private communication, please fill in the form, and in ticket ID provide this query ID which is 13806.
Arturas
