RUT956 FW 7.24.7 OpenVPN fails on latest IOS (3.7.4)/Android(3.7.2⁠) switching from OpenVPN Core 3.11.8 to OpenSSL 3.5.8
When updating apps on Android and IOS OpenVPN fails to connect to the RUT956 with FW 7.24.7 and also older versions, Release Notes for OpenVPN Connect on Android | OpenVPN
Similar OpenVPN configs connects fine on Windows and Linux.
The changelog on OpenVPN has a significant change leaving the OpenVPN Core 3.11.8 to OpenSSL 3.5.8.
OpenSSL on latest RUT956 with FW 7.24.7 seams to be 3.5.7.
Does anybody else have similar issues with OpenVPN on IOS/Android after updating the app?
Any workaround or known issues that Teltonika is working on?
Attempted:
  • regenerating and signed new ca, server and client cert.
  • reviewed the config options
    Same results.
Log on the IOS device
[Nov 02, 2026, 21:01:19] START CONNECTION
[Nov 02, 2026, 21:01:19] ----- OpenVPN Start -----
OpenVPN core 3.11.8 ios arm64 64-bit
[Nov 02, 2026, 21:01:19] OpenVPN core 3.11.8 ios arm64 64-bit
[Nov 02, 2026, 21:01:19] Frame=512/2112/512 control-channel-payload=1170
[Nov 02, 2026, 21:01:19] NOTE: This configuration contains options that were not used:
[Nov 02, 2026, 21:01:19] Unsupported option (ignored)
[Nov 02, 2026, 21:01:19] 0 [resolv-retry] [infinite]
[Nov 02, 2026, 21:01:19] EVENT: RESOLVE
[Nov 02, 2026, 21:01:19] Contacting removed:1194 via UDP
[Nov 02, 2026, 21:01:19] EVENT: WAIT
[Nov 02, 2026, 21:01:19] Connecting to [removed for this post]:1194 (removed for this post) via UDP
[Nov 02, 2026, 21:01:19] EVENT: CONNECTING
[Nov 02, 2026, 21:01:19] Tunnel Options:V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-client
[Nov 02, 2026, 21:01:19] Creds: UsernameEmpty/PasswordEmpty
[Nov 02, 2026, 21:01:19] Clearing credentials
[Nov 02, 2026, 21:01:19] Sending Peer Info:
IV_VER=3.11.8
IV_PLAT=ios
IV_NCP=2
IV_TCPNL=1
IV_PROTO=8094
IV_MTU=1600
IV_CIPHERS=AES-128-CBC:AES-192-CBC:AES-256-CBC:AES-128-GCM:AES-192-GCM:AES-256-GCM:CHACHA20-POLY1305
IV_AUTO_SESS=1
IV_GUI_VER=net.openvpn.connect.ios_3.7.4-7008
IV_SSO=webauth,crtext
[Nov 02, 2026, 21:01:20] Transport Error: OpenSSLContext::SSL::read_cleartext: BIO_read failed, cap=2640 status=-1: error:0A000086:SSL routines::certificate verify failed [unspecified certificate verification error at depth 0]
[Nov 02, 2026, 21:01:20] EVENT: CERT_VERIFY_FAIL OpenSSLContext::SSL::read_cleartext: BIO_read failed, cap=2640 status=-1: error:0A000086:SSL routines::certificate verify failed [unspecified certificate verification error at depth 0] [ERR]
[Nov 02, 2026, 21:01:20] EVENT: DISCONNECTED
[Nov 02, 2026, 21:01:20] EVENT: CORE_THREAD_DONE
[Nov 02, 2026, 21:01:20] EVENT: DISCONNECT_PENDING
[Nov 02, 2026, 21:01:20] Raw stats on disconnect:
BYTES_IN : 2442
BYTES_OUT : 1580
PACKETS_IN : 4
PACKETS_OUT : 5
SSL_ERROR : 1
CERT_VERIFY_FAIL : 1
[Nov 02, 2026, 21:01:20] Performance stats on disconnect:
CPU usage (microseconds): 32967
Network bytes per CPU second: 122000
Tunnel bytes per CPU second: 0
