RUT955 - WiFi Passthrough?
I have a RUT955. I can set it up as a WiFi client and then DHCP on 192.168.2.0/24 - but I was wondering if I could get it to forward the DHCP from the WiFi client it is connected to - acting as a WiFi to LAN switch sortof thing…
We have a Wiki configuration example for your use case: RUTOS relay / Wi-Fi extender / repeater / bridge configuration - Teltonika Networks Wiki
The package RelayD can be downloaded from the Services → Package Manager → Packages menu. This will turn RUT955 into a “dumb” access point, as well as a switch.
Hope this helps!
