we have hundreds of RUT955 routers in operation and production, we are losing them one by one.
They suddenly stop working without the slightest action, at first they work randomly (WiFi works for 5 minutes then stops etc.).
These problem routers can’t even connect to the RMS anymore, so it’s having a huge impact on us.
Their SERIAL changes to 0000000000 and LAN MAC ADRESSE FF:FF:FF:FF:FF, so it can’t connect to RMS.
I managed to recover a router, but after it was reset, I can’t connect to the Webui, it loads in a loop.
I’ve managed to retrieve the router’s logs, which indicate a problem in the board.json file. In fact, this file has only ten lines, whereas on another router that works, this file has more than a hundred lines.
I’ve copied the correct board.json file to the problematic router, and I’m able to connect to the WEBUI, but I’m getting 404 errors on most pages.
I can’t update their firmware: “Error: Incorrect checksum.”
I’ve already tried to completely reset the router with the bootloader.
I manage to downgrade the router to RUT9XX_R_00.06.09.2 but when I upgrade it to the latest versions, the login loopback problem reappears directly after the upgrade. With the error “Failed to load menu”. This is the board.json file :
"model": {
"id": "teltonika,rut9xx",
"name": "Teltonika RUT9XX",
"platform": "RUT9"
"network": {
"lan": {
"default_ip": "192.168.1.1",
"proto": "static"
And few error logs :
Sun Jul 9 19:20:44 2023 cron.err crond[8630]: crond (busybox 1.34.1) started, log level 5
Sun Jul 9 19:20:45 2023 daemon.err mobifd: [] Unable to get SIM count
Sun Jul 9 19:20:48 2023 daemon.err mobifd: [] Unable to get SIM count
Sun Jul 9 19:20:49 2023 daemon.err /usr/sbin/sms_utils: Section ‘smsreboot’ is malformed
Sun Jul 9 19:20:50 2023 daemon.info procd: - init complete -
Sun Jul 9 19:20:50 2023 daemon.info urandom_seed[8853]: Seed saved (/etc/urandom.seed)
Sun Jul 9 19:20:51 2023 daemon.info dfota[7833]: Searching for WAN…
Sun Jul 9 19:20:51 2023 daemon.err mobifd: [] Unable to get SIM count
Sun Jul 9 19:20:54 2023 user.notice simcard: sim UBUS object was not found! Exiting…
Sun Jul 9 19:21:09 2023 daemon.err mobifd: [] Unable to get SIM count
Sun Jul 9 19:21:12 2023 daemon.err mobifd: [] Unable to get SIM count
Sun Jul 9 19:21:15 2023 daemon.err mobifd: [] Unable to get SIM count
Sun Jul 9 19:21:18 2023 daemon.err mobifd: [] Unable to get SIM count
Sun Jul 9 19:21:21 2023 daemon.err mobifd: [1-1.4] Unable to get SIM count
Sun Jul 9 19:21:24 2023 daemon.err mobifd: [1-1.4] Unable to get SIM count
Sun Jul 9 19:21:27 2023 daemon.err mobifd: [1-1.4] Unable to get SIM count
Sun Jul 9 19:22:00 2023 daemon.err mobifd: [1-1.4] Unable to get SIM count
Sun Jul 9 19:22:03 2023 daemon.err mobifd: [1-1.4] Unable to get SIM count
Thanks for your quick help, we have several dozen routers affected.
