a couple of weeks ago, I managed to upgrade to the latest firmware my RUT955.
Since then, the plot of the signal strength in the “metrics” tab of the RMS panel si no longer a continuous and variable curve, but it is a dotted curve, that is with empty spaces among populated values. Since the same time, I started experiencing connection problems, especially local night, so I wonder if this can be connected to the firmware upgrade.
Hello.
Thank you for contacting us.
Interestingly, many factors can affect this.
Test some signals locally, maybe something happened at the service provider.Also Firmware can affect mobile connection, as connection manager in RutOS does ‘interact’ and run modem connection via AT commands it is just an automated process.
If possible, please make a Troubleshoot file and we will check where the problem may be occurring.
Best regards
Andrii.
