Our RUT955 reboots regularly (once or twice a day) without giving any errors. The event log just shows the wifi devices reconnecting and the mobile internet being joined.
It is using the supplied power supply, and that power supply is plugged into a UPS, so the power should be as good as can be.
There is nothing plugged into the USB port.
It is running the latest firmware (RUT9_R_00.07.04.5)
Please could you advise how to diagnose this fault?
Did you notice any particular circumstances, when the reboot occurs, does it happen randomly or with a certain periodicity?
Does your router have any custom configurations or additional packages installed?
Could you log in to the device‘s WebUI and check if there are no running instances in Services → Auto Reboot → Ping/Wget Reboot and Services → Auto Reboot → Reboot Scheduler pages?
Could you login to the router via SSH and provide the output of the command:
df -h
Could you tell, whether the firmware update to 7.4.5 performed with keeping the configuration settings from previous versions? If that is the case, did you try resetting the router to factory default settings?
Hi! Thank you so much for your reply. I’ve just performed a factory reset (holding down the reset button for the right amount of time). I’ve just updated the admin password and WiFi SSID/password and I’ll leave the rest alone for now to see if that resolves it. Will report back in a day or so (or sooner if it keeps resetting) and shall provide the df -h output then.
