RUT955 reboots when logging into webUI
Hello, when trying to connect to RUT955 router’s webUI, it reboots as soon as i log into it so i can’t access the webUI. Tried to connect both, via wifi and ethernet connection, tried to factory reset the router - no success. When trying to update the router through bootloader menu (192.168.1.1/index.html) i get an error “Incorrect checksum”. What’s the problem and how can i fix this?
Hi…
Have you try a legacy firmware?
https://wiki.teltonika-networks.com/images/e/ef/RUT9XX_R_00.06.09.5_WEBUI.bin
https://wiki.teltonika-networks.com/view/RUT955_Firmware_Downloads
Could you please specify the firmware versions you are updating from and to via the Bootloader menu?
Thank you! Tried to load the legacy firmware with bootloader and it worked, i was able to connect to the WebUI. Afterwards I updated the firmware to the latest version from WebUI and the router is now working properly.
I’m glad to hear that the router is working properly now.
Please let me know if you have any further questions or need any assistance.
