each time I log into web interface of rut955 I got an “Instalation wizard”. No matter if I finish it or not I am not able to see Status Overview screen. It is empty, without data.
Resetting to factory default does not help. Firmware updated.
Lots of errors in syslog.
Please let me know what should I do to restore normal operations of the router.
Bests Jack
Thu Jul 13 00:37:12 2023 daemon.info modem_sync[6127]: modem_sync[src/modem_sync.c:187]: Starting modem time sync
Thu Jul 13 00:37:12 2023 daemon.info modem_sync[6127]: modem_sync[src/modem_sync.c:83]: Failed to connect to gsmd socket
Thu Jul 13 00:37:17 2023 daemon.info modem_sync[6198]: modem_sync[src/modem_sync.c:187]: Starting modem time sync
Thu Jul 13 00:37:17 2023 daemon.info modem_sync[6198]: modem_sync[src/modem_sync.c:83]: Failed to connect to gsmd socket
Thu Jul 13 00:37:22 2023 daemon.info modem_sync[6244]: modem_sync[src/modem_sync.c:187]: Starting modem time sync
Thu Jul 13 00:37:22 2023 daemon.info modem_sync[6244]: modem_sync[src/modem_sync.c:83]: Failed to connect to gsmd socket
Thu Jul 13 00:37:35 2023 user.notice root: /usr/lib/lua/luci/dispatcher.lua:224: Failed to execute template dispatcher target for entry ‘/admin/status/overview’. The called action terminated with an exception: /usr/lib/lua/luci/template.lua:17: Failed to execute template ‘admin_status/index’. A runtime error occured: /usr/lib/lua/luci/i18n.lua:6: bad argument #1 to ‘lookup’ (string expected, got nil) stack traceback: [C]: in function ‘assert’ /usr/lib/lua/luci/dispatcher.lua:224: in function ‘dispatch’ /usr/lib/lua/luci/dispatcher.lua:98: in function </usr/lib/lua/luci/dispatcher.lua:98>
Thu Jul 13 00:37:37 2023 daemon.info procd: Instance modem_sync::instance1 s in a crash loop 6 crashes, 0 seconds since last crash
Thu Jul 13 00:37:39 2023 user.notice root: /usr/lib/lua/luci/dispatcher.lua:224: Failed to execute template dispatcher target for entry ‘/admin/status/overview’. The called action terminated with an exception: /usr/lib/lua/luci/template.lua:17: Failed to execute template ‘admin_status/index’. A runtime error occured: /usr/lib/lua/luci/i18n.lua:6: bad argument #1 to ‘lookup’ (string expected, got nil) stack traceback: [C]: in function ‘assert’ /usr/lib/lua/luci/dispatcher.lua:224: in function ‘dispatch’ /usr/lib/lua/luci/dispatcher.lua:98: in function </usr/lib/lua/luci/dispatcher.lua:98>
Thu Jul 13 00:37:44 2023 user.notice root: /usr/lib/lua/luci/dispatcher.lua:224: Failed to execute template dispatcher target for entry ‘/admin/status/overview’. The called action terminated with an exception: /usr/lib/lua/luci/template.lua:17: Failed to execute template ‘admin_status/index’. A runtime error occured: /usr/lib/lua/luci/i18n.lua:6: bad argument #1 to ‘lookup’ (string expected, got nil) stack traceback: [C]: in function ‘assert’ /usr/lib/lua/luci/dispatcher.lua:224: in function ‘dispatch’ /usr/lib/lua/luci/dispatcher.lua:98: in function </usr/lib/lua/luci/dispatcher.lua:98>
Thu Jul 13 00:37:59 2023 user.notice root: /usr/lib/lua/luci/dispatcher.lua:224: Failed to execute template dispatcher target for entry ‘/admin/status/netinfo/mobile’. The called action terminated with an exception: /usr/lib/lua/luci/template.lua:17: Failed to execute template ‘admin_status/netinfo_lte’. A runtime error occured: /usr/lib/lua/luci/i18n.lua:6: bad argument #1 to ‘lookup’ (string expected, got nil) stack traceback: [C]: in function ‘assert’ /usr/lib/lua/luci/dispatcher.lua:224: in function ‘dispatch’ /usr/lib/lua/luci/dispatcher.lua:98: in function </usr/lib/lua/luci/dispatcher.lua:98>
Thu Jul 13 00:40:04 2023 local1.crit luci-reload[7640]: START==1
Thu Jul 13 00:40:11 2023 local1.crit luci-reload[7683]: START==1
