Is it possible to setup the RUT955 as a Modbus master and then write internal values to registers in slave devices?
I require to write the GPS coordinates
When configuring modbus requests in Modbus Master, you can specify a function to set coil or holding registers. I suggest taking a look at our wiki page here for more information on the available options.
