Rut955 Mobil Probleme
Hallo ich bekomme die mobile Verbindung nicht richtig eingerichtet.
WLAN meldet keine Internet Verbindung.
Bei Cell Info ist der Wert RSRP auf rot, -102 no signal
Wo kann das Problem liegen?
Neueste Firmware ist installiert
The value RSRP -102 dBm indicates a very poor signal strength, which can cause an unstable connection or no internet at all.
In this case, firsly:
  1. Make sure the mobile antennas are properly connected and tightly screwed in.
  2. Verify that the correct APN for your operator is selected (if set to Auto, please try selecting it manually).
  3. Could you provide a screenshot from Status → Network → Mobile to check the signal values in detail? Please ensure that sensitive information (e.g., public IP, IMSI, ICCID, cell ID) is hidden.
Additionally, I suggest checking our wiki article on mobile signal improvement for optimal performance available here:
