RUT955 GPS NMEA Data
The RUT955 has an option to collect NMEA data. Is there a way to have this data uploaded to a remote storage location or is it only local?
Thanks!
If you want to send GPS data to a remote host, I would suggest forwarding NMEA data to your device either via direct NMEA forwarding or by sending it to your HTTP server. Of course, in this case you will need to accept and process this data on your remote device appropriately.
In case you want to actually collect and store the data in a file, and then move the file to a remote host, I would suggest the following.
Collect and store NMEA locally, and then use a script to transfer the file periodically. If this is something that you are looking to do, I would suggest looking at this forum post here which explains how you can do that.
