Although ZygimantasBliu from Teltonika replied to my question already with "
I will consult the developers about this issue.
", and although I had to recreate my user account because mine was deleted (as the question was), I still have the same problem with the router…
I would appreciate, if someone from Teltonika could meaningful react to my request (I just paste it again - I would also like to attach the pictures and the error protocol, but this “wiki” doesn’t allow attaching files anymore):
Since I travelled through Albania I cannot get any internet connection any more. I had a working setup, and from one day to the other things didn’t work any more.
The device finds a LTE-band on which it could connect (because the signal is good, the SIM-credentials are right, and there is nothing configured that does prohibit the use of that connection), but the device keeps on searching some other band. Even if I force the router to use this connection, he finds it, but he does not connect to.
To get a reproducible state to find the error, I did a complete factory reset - but still: no connection at all.
Now, I am in Greece, and I use the same Vodafone card that I was using some month ago, but also here: no connection.
“Sadly”, everything works well with my Huawei-USB-Stick - in Albania and also in Greece.
To sum it up, here is what I do (but it leaves me without a working internet connection):
Factory reset
Connect by wire
Try to log in with old credentials (failed)
Log in with factory credentials (admin admin01)
Set new admin password
Within the displayed wizard, adjusted time and date to browser time/date
Leave LAN settings as is
Mobile settings: adjusted to use custom APN (“internet”) without authentication and without PIN (not even entered into the PIN-field)
Leave Wireless settings as is (pw: z2P4RmUd)
Disabled RMS and Finished wizard
Took some screenshots of the mobile connection state (attached)
Disconnected the antenna
Took screenshot of the mobile connection state (attached with name no_antenna.png)
Generated troubleshoot file (attached)
Verified that the connection works with my HUAWEI-Stick with same APN/PIN settings (on the picture you can see that traceroute uses 192.168.8.1, which is the huawei modem)
So: I can see, that there is a good signal with which the modem could connect, but it does not.
I spent already hours (!!!) to find a solution (most of the time waiting for reboot- or config- beeing applied… … … … … waiting, and waiting…)
Could you please tell me, what I can do, to get this thing working. Do I need a new Router? Is it broke?
Kind regards
Stefan Messmer
