When using the modem web site trying to send i receive error “Failed to send message or SMS limit was reached”. This appears after more than a minute waiting.
Same thing happened yesterday and we then switched SIM card and it work fine until today where the same problem occured again.
Enable SMS limit is disabled.
If I push button Clear SMS limit it works again.
Why do I have to clear this and how long will it work this time?
I would suggest restoring the device to factory settings as this may be due to configuration issues. If you are using the latest firmware version, try restoring the device to factory settings. If not, could you please update with the ‘keep settings’ options disabled to avoid any potential migration issues?
