A few months back my RUT951 stopped sending SMS messages. The only diagnostic message I have been able to find is:
Example 1 - reply to SMS - iostatus
559 Thu Aug 28 15:23:03 2025 kern.notice kernel: SMS received from: +39xxxxxx718 (internal modem)
560 Thu Aug 28 15:23:03 2025 daemon.notice urcd: Notice: ‘ip_block’ was restarted. Retrying to check for blocked numbers.
561 Thu Aug 28 15:23:51 2025 daemon.err /usr/sbin/sms_utils: [1-1] Failed to send SMS message ‘Input (3) - Off; Output (4) - High level;’ to ‘+39xxxxxx718’
562 Thu Aug 28 15:23:51 2025 daemon.info /usr/sbin/sms_utils: Removing SMS ‘0’ from memory
Example 2 - reply to SMS - status
574 Thu Aug 28 15:36:54 2025 kern.notice kernel: SMS received from: ++39xxxxxx718 (internal modem)
575 Thu Aug 28 15:36:59 2025 daemon.info urcd: Removing SMS ‘0’ from memory
576 Thu Aug 28 15:37:09 2025 daemon.err urcd: Failed to Remove SMS ‘0’
577 Thu Aug 28 15:37:10 2025 daemon.info urcd: Removing SMS ‘0’ from memory
578 Thu Aug 28 15:37:20 2025 daemon.err urcd: Failed to Remove SMS ‘0’
579 Thu Aug 28 15:37:21 2025 daemon.info urcd: Removing SMS ‘0’ from memory
580 Thu Aug 28 15:37:31 2025 daemon.err urcd: Failed to Remove SMS ‘0’
581 Thu Aug 28 15:37:32 2025 daemon.info urcd: Removing SMS ‘0’ from memory
582 Thu Aug 28 15:37:42 2025 daemon.err urcd: Failed to Remove SMS ‘0’
583 Thu Aug 28 15:37:43 2025 daemon.err /usr/sbin/sms_utils: [1-1] Failed to send SMS message ‘Router name - RUT951; WAN IP - 10.70.250.6; Data Connection state - Connected; Network type - LTE; Signal Strength - -45; New FW available - No;’ to ‘+39xxxxxx718’
584 Thu Aug 28 15:37:43 2025 kern.notice kernel: SMS received from: +39xxxxxx718 (internal modem)
585 Thu Aug 28 15:38:31 2025 daemon.err /usr/sbin/sms_utils: [1-1] Failed to send SMS message ‘Input (3) - Off; Output (4) - High level;’ to ‘+39xxxxxx718’
Thanks in advance for any help !
