Rut950 with starlink wan
I have a RUT950 and I’ve just installed Starlink to the WAN port. However the speed is decreased. It will stop at 20Mb/s. Seems to be a limit due to the Teltonika RUT950.
Is there any way to configure the router to allow full speed? I’ve seen similar posts about this, but not found sn amswer.
Thanks for any input or support
Hello Marijus,
By default, there are no speed limitations for WAN or LAN ports. To obtain a clear measurement of the expected Starlink speed, I recommend testing the speed with another router/device. This will help determine if the issue lies with the RUT950 or elsewhere.
Marijus
Thanks, I will try that.
Good to know nothing should be limiting. Might be my wires too.
