RUT950 Web Server not responding
Suddendly my RUT950 doesn’t answer as web server, so I cannot access it to change parameters. I rebooted it several times ; the firmware is uddated to the latest versin.
THanks in advance for any help
Could you please provide more details about the term “suddenly” in this context? Did the device become inaccessible without any external interventions, or could there have been changes to its configurations?
Please, try following the bootloader procedure as described here.
Hello thre, thank you for your fast answer.
My router RUT950 worked fine for about a year in a remote area of center of Italy, where the LTE signal strenght was normally about - 105 dB; recently ( a month ago) I updated the firmware at the latest version.
Since about a week the router continue working quite fime with the cabled (LAN) devices connected ( two IP cam) but the wifi signal comes and goes continuosly not permitting me to work with tablet or phones.
I tried to connect to the router via webserver but it is appears in the list with correct static IP but is unreacheable. On the other hand I tried to connect with SSH using bot admin with the default password admin01 and password of router I commonly use, but it says access denied.
I tried several times to reboot it cutting power supply with the same results.
Hope this could help you
regards
Alberto
When you say webserver, I assume you mean the web interface of RUT950. Is that correct?
Also, could you please clarify if you can load the webpage or the page is completely unreachable?
Since there are also WiFi issues, the first thing I would suggest is to restore the device to factory defaults via a button as described here. It is possible that there were some issues with configurations when migrating to a newer firmware version.
yes, I mean that the web interface is complitely unreachable, also if the router mantains the correct ip address and all the parts concerning the cabled LAN are working as usual; when I return to the location where router is placed I try to reset it via reset button as suggested. thanks a lot for now for you kind assistance.
regards
Alberto
