I changed to SIM-card 2, but its the same problem.
Works fine for 1-2 days and then it stops.
[Logread]
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.000000] Linux version 5.4.229 (app@runner-ffjpezdj-project-352-concurrent-0) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16279-5cc0535800)) #0 Mon Jul 24 11:59:22 2023
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] printk: bootconsole [early0] enabled
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] CPU0 revision is: 0001974c (MIPS 74Kc)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] MIPS: machine is Teltonika RUT9XX
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] SoC: Atheros AR9344 rev 2
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Thu Oct 5 13:44:15 2023 kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Thu Oct 5 13:44:15 2023 kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] Zone ranges:
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] Movable zone start for each node
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] Early memory node ranges
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
Thu Oct 5 13:44:15 2023 kern.debug kernel: [ 0.000000] On node 0 totalpages: 32768
Thu Oct 5 13:44:15 2023 kern.debug kernel: [ 0.000000] Normal zone: 256 pages used for memmap
Thu Oct 5 13:44:15 2023 kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Thu Oct 5 13:44:15 2023 kern.debug kernel: [ 0.000000] Normal zone: 32768 pages, LIFO batch:7
Thu Oct 5 13:44:15 2023 kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=132768
Thu Oct 5 13:44:15 2023 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] Memory: 123668K/131072K available (4036K kernel code, 157K rwdata, 620K rodata, 1196K init, 187K bss, 7404K reserved, 0K cma-reserved)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] NR_IRQS: 51
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] CPU clock: 550.000 MHz
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6950037990 ns
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.000011] sched_clock: 32 bits at 275MHz, resolution 3ns, wraps every 7809031678ns
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.008777] Calibrating delay loop… 273.66 BogoMIPS (lpj=547328)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.055655] pid_max: default: 32768 minimum: 301
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.061008] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.069173] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.083594] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.094516] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.102175] pinctrl core: initialized pinctrl subsystem
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.109864] NET: Registered protocol family 16
Thu Oct 5 13:44:15 2023 kern.warn kernel: [ 0.148466] gpio-17 (i2c@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
Thu Oct 5 13:44:15 2023 kern.warn kernel: [ 0.158686] gpio-16 (i2c@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.169132] i2c-gpio i2c@0: using lines 17 (SDA) and 16 (SCL)
Thu Oct 5 13:44:15 2023 kern.warn kernel: [ 0.175923] workqueue: max_active 576 requested for napi_workq is out of range, clamping between 1 and 512
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.191677] clocksource: Switched to clocksource MIPS
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.198771] NET: Registered protocol family 2
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.204013] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.213115] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.222548] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.231126] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.239016] TCP: Hash tables configured (established 1024 bind 1024)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.246270] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.253625] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.261761] NET: Registered protocol family 1
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.266701] PCI: CLS 0 bytes, default 32
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.276091] workingset: timestamp_bits=30 max_order=15 bucket_order=0
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.290697] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.297252] squashfs: patched 4.0 (2020/11/10) Oever Gonzalez
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.303672] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.333067] pinctrl-single 1804002c.pinmux: 544 pins, size 68
Thu Oct 5 13:44:15 2023 kern.err kernel: [ 0.345763] spi spi0.1: INFO: gpio[3] set up status(0)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.352566] shift_io@0 enforce active low on chipselect handle
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.374402] spi-nor spi0.0: w25q128 (16384 Kbytes)
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.379829] 5 fixed-partitions partitions found on MTD device spi0.0
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.386925] Creating 5 MTD partitions on “spi0.0”:
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.392298] 0x000000000000-0x000000020000 : “u-boot”
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.399002] 0x000000020000-0x000000030000 : “config”
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.405748] 0x000000030000-0x000000040000 : “art”
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.412260] 0x000000040000-0x000000f70000 : “firmware”
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.423649] 2 tplink-fw partitions found on MTD device firmware
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.430318] Creating 2 MTD partitions on “firmware”:
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.435876] 0x000000000000-0x00000018d843 : “kernel”
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.442593] 0x00000018d844-0x000000f30000 : “rootfs”
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.449247] mtd: device 5 (rootfs) set to be root filesystem
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.458000] 1 squashfs-split partitions found on MTD device rootfs
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.464980] 0x000000bd0000-0x000000f30000 : “rootfs_data”
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 0.472279] 0x000000f70000-0x000001000000 : “event-log”
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.479772] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.487902] printk: console [ttyS0] disabled
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.492773] 18020000.uart: ttyS0 at MMIO 0x18020000 (irq = 9, base_baud = 2500000) is a 16550A
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.502429] printk: console [ttyS0] enabled
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.511345] printk: bootconsole [early0] disabled
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 0.527211] 18500000.uart: ttyATH1 at MMIO 0x18500000 (irq = 12, base_baud = 2500000) is a AR933X UART
Thu Oct 5 13:44:15 2023 kern.err kernel: [ 0.876789] ag71xx 19000000.eth: Could not connect to PHY device. Deferring probe.
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 1.525677] switch0: Atheros AR8229 rev. 1 switch registered on mdio.0
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 1.569725] ag71xx 1a000000.eth: connected to PHY at fixed-0:00 [uid=00000000, driver=Generic PHY]
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 1.579792] eth0: Atheros AG71xx at 0xba000000, irq 5, mode: gmii
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 1.586303] i2c /dev entries driver
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 1.599960] NET: Registered protocol family 10
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 1.610622] Segment Routing with IPv6
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 1.614587] NET: Registered protocol family 17
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 1.619567] 8021q: 802.1Q VLAN Support v1.8
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 1.626262] gpio-export gpio-export: 5 gpio(s) exported
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 1.949634] ag71xx 19000000.eth: connected to PHY at mdio.0:1f:04 [uid=004dd042, driver=Generic PHY]
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 1.960263] eth1: Atheros AG71xx at 0xb9000000, irq 4, mode: mii
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 1.971619] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 1.985831] Freeing unused kernel memory: 1196K
Thu Oct 5 13:44:15 2023 kern.warn kernel: [ 1.990467] This architecture does not have kernel memory protection.
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 1.997013] Run /sbin/init as init process
Thu Oct 5 13:44:15 2023 user.info kernel: [ 2.631558] init: Console is alive
Thu Oct 5 13:44:15 2023 user.info kernel: [ 2.635434] init: - watchdog -
Thu Oct 5 13:44:15 2023 user.info kernel: [ 5.204097] kmodloader: loading kernel modules from /etc/modules-boot.d/
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 5.394202] usbcore: registered new interface driver usbfs
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 5.399922] usbcore: registered new interface driver hub
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 5.405455] usbcore: registered new device driver usb
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 5.574321] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 5.592615] SCSI subsystem initialized
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 5.604532] ehci-fsl: Freescale EHCI Host controller driver
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 5.613191] ehci-platform: EHCI generic platform driver
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 5.618898] ehci-platform 1b000000.usb: EHCI Host Controller
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 5.624763] ehci-platform 1b000000.usb: new USB bus registered, assigned bus number 1
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 5.632861] ehci-platform 1b000000.usb: irq 3, io mem 0x1b000000
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 5.651699] ehci-platform 1b000000.usb: USB 2.0 started, EHCI 1.00
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 5.659090] hub 1-0:1.0: USB hub found
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 5.663534] hub 1-0:1.0: 1 port detected
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 5.722991] usbcore: registered new interface driver usb-storage
Thu Oct 5 13:44:15 2023 user.info kernel: [ 5.734349] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Thu Oct 5 13:44:15 2023 user.info kernel: [ 5.752280] init: - preinit -
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 5.979579] usb 1-1: new high-speed USB device number 2 using ehci-platform
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 6.275281] random: procd: uninitialized urandom read (4 bytes read)
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 7.560814] random: jshn: uninitialized urandom read (4 bytes read)
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 7.660837] random: jshn: uninitialized urandom read (4 bytes read)
Thu Oct 5 13:44:15 2023 user.info kernel: [ 7.868134] mount_root: loading kmods from internal overlay
Thu Oct 5 13:44:15 2023 user.info kernel: [ 7.988071] kmodloader: loading kernel modules from //etc/modules-boot.d/*
Thu Oct 5 13:44:15 2023 user.info kernel: [ 7.997331] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 8.755813] jffs2: notice: (614) jffs2_build_xattr_subsystem: complete building xattr subsystem, 39 of xdatum (35 unchecked, 3 orphan) and 51 of xref (3 dead, 0 orphan) found.
Thu Oct 5 13:44:15 2023 user.info kernel: [ 8.772618] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
Thu Oct 5 13:44:15 2023 user.info kernel: [ 8.791854] block: extroot: not configured
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 8.865521] jffs2: notice: (612) jffs2_build_xattr_subsystem: complete building xattr subsystem, 39 of xdatum (35 unchecked, 3 orphan) and 51 of xref (3 dead, 0 orphan) found.
Thu Oct 5 13:44:15 2023 user.info kernel: [ 9.401554] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
Thu Oct 5 13:44:15 2023 user.info kernel: [ 9.420097] block: extroot: not configured
Thu Oct 5 13:44:15 2023 user.info kernel: [ 9.425754] mount_root: switching to jffs2 overlay
Thu Oct 5 13:44:15 2023 kern.warn kernel: [ 9.436301] overlayfs: upper fs does not support tmpfile.
Thu Oct 5 13:44:15 2023 user.warn kernel: [ 9.447202] urandom-seed: Seeding with /etc/urandom.seed
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 9.651955] random: mctl: uninitialized urandom read (4 bytes read)
Thu Oct 5 13:44:15 2023 user.info kernel: [ 9.852305] procd: - early -
Thu Oct 5 13:44:15 2023 user.info kernel: [ 9.855368] procd: - watchdog -
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 10.216863] random: jshn: uninitialized urandom read (4 bytes read)
Thu Oct 5 13:44:15 2023 user.info kernel: [ 10.499174] procd: - watchdog -
Thu Oct 5 13:44:15 2023 user.info kernel: [ 10.517109] procd: - ubus -
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 10.549450] random: jshn: uninitialized urandom read (4 bytes read)
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 10.655913] random: ubusd: uninitialized urandom read (4 bytes read)
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 10.676388] random: ubusd: uninitialized urandom read (4 bytes read)
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 10.688419] random: ubusd: uninitialized urandom read (4 bytes read)
Thu Oct 5 13:44:15 2023 user.info kernel: [ 10.721034] procd: - init -
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 12.287856] random: jshn: uninitialized urandom read (4 bytes read)
Thu Oct 5 13:44:15 2023 user.info kernel: [ 13.307872] urngd: v1.0.2 started.
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 13.685905] random: crng init done
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 13.689428] random: 28 urandom warning(s) missed due to ratelimiting
Thu Oct 5 13:44:15 2023 kern.notice kernel: [ 13.704819] jffs2: notice: (820) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
Thu Oct 5 13:44:15 2023 user.info kernel: [ 14.199288] kmodloader: loading kernel modules from /etc/modules.d/*
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 14.415169] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 14.442882] NET: Registered protocol family 15
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 14.456534] Initializing XFRM netlink socket
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 14.469230] tun: Universal TUN/TAP device driver, 1.6
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 14.559140] l2tp_core: L2TP core driver, V2.0
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 14.573739] l2tp_netlink: L2TP netlink interface
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 14.591287] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 14.625700] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 14.635011] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 14.658099] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 14.745611] gre: GRE over IPv4 demultiplexor driver
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 14.770844] ip_gre: GRE over IPv4 tunneling driver
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 14.825254] ip6_gre: GRE over IPv6 tunneling driver
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 15.079779] fuse: init (API version 7.31)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 15.213091] usbcore: registered new interface driver cdc_acm
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 15.218900] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 15.246524] usbcore: registered new interface driver cdc_wdm
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 15.273442] Loading modules backported from Linux version v5.10.68-0-g4d8524048a35
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 15.281188] Backport generated by backports.git v5.10.68-1-0-ga4f9ba32
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 15.499996] mcp3021 0-004d: Scanning address range.
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 15.720195] usbcore: registered new interface driver usblp
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 15.784123] usbcore: registered new interface driver usbserial_generic
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 15.790939] usbserial: USB Serial support registered for generic
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 15.916931] xt_time: kernel timezone is -0000
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 15.941879] usbcore: registered new interface driver ark3116
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 15.947819] usbserial: USB Serial support registered for ark3116
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 15.997822] usbcore: registered new interface driver belkin_sa
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.003952] usbserial: USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.286693] usbcore: registered new interface driver ch341
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.292448] usbserial: USB Serial support registered for ch341-uart
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.304466] usbcore: registered new interface driver cp210x
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.310298] usbserial: USB Serial support registered for cp210x
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.321151] usbcore: registered new interface driver cypress_m8
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.327354] usbserial: USB Serial support registered for DeLorme Earthmate USB
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.334844] usbserial: USB Serial support registered for HID->COM RS232 Adapter
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.342413] usbserial: USB Serial support registered for Nokia CA-42 V2 Adapter
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.362186] usbcore: registered new interface driver ftdi_sio
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.368230] usbserial: USB Serial support registered for FTDI USB Serial Device
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.681066] usbcore: registered new interface driver pl2303
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.686925] usbserial: USB Serial support registered for pl2303
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.701370] PPP generic driver version 2.4.2
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.709021] PPP MPPE Compression module registered
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.717402] NET: Registered protocol family 24
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.724913] PPTP driver version 0.8.5
Thu Oct 5 13:44:15 2023 kern.warn kernel: [ 16.737674] qmi_wwan: probe of 1-1:1.4 failed with error -22
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.746166] qmi_wwan 1-1:1.5: cdc-wdm0: USB WDM device
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.761097] qmi_wwan 1-1:1.5 wwan0: register ‘qmi_wwan’ at usb-1b000000.usb-1, WWAN/QMI device, 3e:cb:50:65:35:66
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.771855] usbcore: registered new interface driver qmi_wwan
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.824489] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 16.832495] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld Jason@zx2c4.com. All Rights Reserved.
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 17.172085] l2tp_ppp: PPPoL2TP kernel driver, V2.0
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 17.195874] usbcore: registered new interface driver option
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 17.201696] usbserial: USB Serial support registered for GSM modem (1-port)
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 17.209312] option 1-1:1.0: GSM modem (1-port) converter detected
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 17.215955] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 17.223359] option 1-1:1.1: GSM modem (1-port) converter detected
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 17.229989] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 17.237383] option 1-1:1.2: GSM modem (1-port) converter detected
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 17.244043] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 17.251452] option 1-1:1.3: GSM modem (1-port) converter detected
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 17.258088] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB3
Thu Oct 5 13:44:15 2023 kern.debug kernel: [ 17.408238] ath: EEPROM regdomain sanitized
Thu Oct 5 13:44:15 2023 kern.debug kernel: [ 17.408252] ath: EEPROM regdomain: 0x64
Thu Oct 5 13:44:15 2023 kern.debug kernel: [ 17.408257] ath: EEPROM indicates we should expect a direct regpair map
Thu Oct 5 13:44:15 2023 kern.debug kernel: [ 17.408284] ath: Country alpha2 being used: 00
Thu Oct 5 13:44:15 2023 kern.debug kernel: [ 17.408289] ath: Regpair used: 0x64
Thu Oct 5 13:44:15 2023 kern.debug kernel: [ 17.422150] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
Thu Oct 5 13:44:15 2023 kern.info kernel: [ 17.424920] ieee80211 phy0: Atheros AR9340 Rev:2 mem=0xb8100000, irq=13
Thu Oct 5 13:44:15 2023 user.info kernel: [ 17.460627] kmodloader: done loading kernel modules from /etc/modules.d/*
Thu Oct 5 13:44:18 2023 user.notice : Added device handler type: bonding
Thu Oct 5 13:44:18 2023 user.notice : Added device handler type: 8021ad
Thu Oct 5 13:44:18 2023 user.notice : Added device handler type: 8021q
Thu Oct 5 13:44:18 2023 user.notice : Added device handler type: macvlan
Thu Oct 5 13:44:18 2023 user.notice : Added device handler type: veth
Thu Oct 5 13:44:18 2023 user.notice : Added device handler type: bridge
Thu Oct 5 13:44:18 2023 user.notice : Added device handler type: Network device
Thu Oct 5 13:44:18 2023 user.notice : Added device handler type: tunnel
Thu Oct 5 13:44:20 2023 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Thu Oct 5 13:44:20 2023 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Thu Oct 5 13:44:21 2023 daemon.info dnsmasq[1938]: Connected to system UBus
Thu Oct 5 13:44:21 2023 daemon.info dnsmasq[1938]: started, version 2.85 cachesize 150
Thu Oct 5 13:44:21 2023 daemon.info dnsmasq[1938]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Thu Oct 5 13:44:21 2023 daemon.info dnsmasq[1938]: UBus support enabled: connected to system bus
Thu Oct 5 13:44:21 2023 daemon.info dnsmasq[1938]: using only locally-known addresses for domain test
Thu Oct 5 13:44:21 2023 daemon.info dnsmasq[1938]: using only locally-known addresses for domain onion
Thu Oct 5 13:44:21 2023 daemon.info dnsmasq[1938]: using only locally-known addresses for domain localhost
Thu Oct 5 13:44:21 2023 daemon.info dnsmasq[1938]: using only locally-known addresses for domain invalid
Thu Oct 5 13:44:21 2023 daemon.info dnsmasq[1938]: using only locally-known addresses for domain bind
Thu Oct 5 13:44:21 2023 daemon.info dnsmasq[1938]: using only locally-known addresses for domain lan
Thu Oct 5 13:44:21 2023 daemon.warn dnsmasq[1938]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Thu Oct 5 13:44:21 2023 daemon.info dnsmasq[1938]: read /etc/hosts - 1 addresses
Thu Oct 5 13:44:21 2023 daemon.info dnsmasq[1938]: read /tmp/hosts/dhcp.cfg01411c - 0 addresses
Thu Oct 5 13:44:24 2023 daemon.notice wpa_supplicant[1994]: Successfully initialized wpa_supplicant
Thu Oct 5 13:44:26 2023 daemon.info gsmd[2107]: gsmd-ng init
Thu Oct 5 13:44:26 2023 daemon.info gsmd[2107]: gsmd-ng canary build git#ef0afca924
Thu Oct 5 13:44:26 2023 daemon.info gsmd[2107]: Log compression support: no
Thu Oct 5 13:44:26 2023 daemon.info gsmd[2107]: Baseband feature support: no
Thu Oct 5 13:44:26 2023 daemon.info gsmd[2107]: gsmd-ng running
Thu Oct 5 13:44:27 2023 user.notice /bin/trigger_vuci_routes_reload: vuci reload_routes triggered
Thu Oct 5 13:44:35 2023 daemon.info mobifd: [gsm.modem0] Initializing modem. Please wait.
Thu Oct 5 13:44:38 2023 daemon.warn netifd: You have delegated IPv6-prefixes but haven’t assigned them to any interface. Did you forget to set option ip6assign on your lan-interfaces?
Thu Oct 5 13:44:39 2023 kern.info kernel: [ 47.698576] eth0: link up (1000Mbps/Full duplex)
Thu Oct 5 13:44:39 2023 kern.info kernel: [ 47.736074] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Thu Oct 5 13:44:39 2023 kern.info kernel: [ 47.772147] br-lan: port 1(eth0.1) entered blocking state
Thu Oct 5 13:44:39 2023 kern.info kernel: [ 47.777704] br-lan: port 1(eth0.1) entered disabled state
Thu Oct 5 13:44:39 2023 kern.info kernel: [ 47.783598] device eth0.1 entered promiscuous mode
Thu Oct 5 13:44:39 2023 kern.info kernel: [ 47.788525] device eth0 entered promiscuous mode
Thu Oct 5 13:44:39 2023 kern.info kernel: [ 47.914482] br-lan: port 1(eth0.1) entered blocking state
Thu Oct 5 13:44:39 2023 kern.info kernel: [ 47.920041] br-lan: port 1(eth0.1) entered forwarding state
Thu Oct 5 13:44:39 2023 daemon.notice netifd: Interface ‘lan’ is enabled
Thu Oct 5 13:44:39 2023 daemon.notice netifd: Interface ‘lan’ is setting up now
Thu Oct 5 13:44:40 2023 daemon.notice netifd: Interface ‘lan’ is now up
Thu Oct 5 13:44:40 2023 daemon.notice netifd: bridge ‘br-lan’ link is up
Thu Oct 5 13:44:40 2023 daemon.notice netifd: Interface ‘lan’ has link connectivity
Thu Oct 5 13:44:40 2023 daemon.notice netifd: Interface ‘loopback’ is enabled
Thu Oct 5 13:44:40 2023 daemon.notice netifd: Interface ‘loopback’ is setting up now
Thu Oct 5 13:44:40 2023 daemon.notice netifd: Interface ‘loopback’ is now up
Thu Oct 5 13:44:40 2023 daemon.notice netifd: Interface ‘wan’ is enabled
Thu Oct 5 13:44:40 2023 daemon.notice netifd: Network device ‘eth0’ link is up
Thu Oct 5 13:44:40 2023 daemon.notice netifd: VLAN ‘eth0.1’ link is up
Thu Oct 5 13:44:40 2023 daemon.notice netifd: Network device ‘lo’ link is up
Thu Oct 5 13:44:40 2023 daemon.notice netifd: Interface ‘loopback’ has link connectivity
Thu Oct 5 13:44:40 2023 kern.info kernel: [ 48.682255] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Thu Oct 5 13:44:42 2023 authpriv.info dropbear[2579]: Not backgrounding
Thu Oct 5 13:44:46 2023 user.warn mwan3-hotplug[2497]: hotplug called on lan before mwan3 has been set up
Thu Oct 5 13:44:47 2023 kern.debug kernel: [ 55.515878] ath: EEPROM regdomain: 0x8348
Thu Oct 5 13:44:47 2023 kern.debug kernel: [ 55.519990] ath: EEPROM indicates we should expect a country code
Thu Oct 5 13:44:47 2023 kern.debug kernel: [ 55.526203] ath: doing EEPROM country->regdmn map search
Thu Oct 5 13:44:47 2023 kern.debug kernel: [ 55.531607] ath: country maps to regdmn code: 0x3a
Thu Oct 5 13:44:47 2023 kern.debug kernel: [ 55.536481] ath: Country alpha2 being used: US
Thu Oct 5 13:44:47 2023 kern.debug kernel: [ 55.541002] ath: Regpair used: 0x3a
Thu Oct 5 13:44:47 2023 kern.debug kernel: [ 55.544559] ath: regdomain 0x8348 dynamically updated by user
Thu Oct 5 13:44:48 2023 daemon.notice netifd: Wireless device ‘radio0’ is now up
Thu Oct 5 13:44:49 2023 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Thu Oct 5 13:44:52 2023 kern.notice Port link state of port CPU/WiFi changed to UP
Thu Oct 5 13:44:52 2023 kern.notice Port speed for port CPU/WiFi changed to 1000 baseT
Thu Oct 5 13:44:52 2023 kern.notice Port link state of port LAN1 changed to UP
Thu Oct 5 13:44:52 2023 kern.notice Port speed for port LAN1 changed to 100 baseT
Thu Oct 5 13:44:52 2023 daemon.info dnsmasq[1938]: exiting on receipt of SIGTERM
Thu Oct 5 13:44:53 2023 daemon.info dnsmasq[3202]: Connected to system UBus
Thu Oct 5 13:44:53 2023 daemon.info dnsmasq[3202]: started, version 2.85 cachesize 150
Thu Oct 5 13:44:53 2023 daemon.info dnsmasq[3202]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
