RUT950 OpenVPN Problem - Status wrong
Hi Team,
i updated firmware RUT9_R_00.07.05.4 to RUT9_R_00.07.06.12
On 07.05.4 the OpenVPN works finde.
On 07.06.12 the status is Disconnected but i see traffic and no error in the log
if i downgrade vom 7.6.12 to 7.5.4 it works fine again.
seems that there is an bug in the 7.6.12???
Log:
Mon Jun 24 20:56:47 2024 daemon.warn openvpn(xxx)[10850]: Multiple --down scripts defined.  The previously configured script is overridden.
Mon Jun 24 20:56:47 2024 daemon.warn openvpn(xxx)[10850]: Multiple --up scripts defined.  The previously configured script is overridden.
Mon Jun 24 20:56:47 2024 xxxxxx: OpenVPN 2.5.3 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Mon Jun 24 20:56:47 2024 xxxxxx: library versions: OpenSSL 3.0.12 24 Oct 2023, LZO 2.10
Mon Jun 24 20:56:47 2024 daemon.warn openvpn(xxx)[10850]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mon Jun 24 20:56:48 2024 xxxxxx: Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Mon Jun 24 20:56:48 2024 xxxxxx: Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Mon Jun 24 20:56:48 2024 xxxxxx: Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
Mon Jun 24 20:56:48 2024 xxxxxx: Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
Mon Jun 24 20:56:48 2024 xxxxxx: TCP/UDP: Preserving recently used remote address: [AF_INET]x.x.x.x.x.x.x.x.
Mon Jun 24 20:56:48 2024 xxxxxx: Socket Buffers: R=[8388608->8388608] S=[8388608->8388608]
Mon Jun 24 20:56:48 2024 xxxxxx: UDP link local: (not bound)
Mon Jun 24 20:56:48 2024 xxxxxx: UDP link remote: [AF_INET]x.x.x.x.xx.
Mon Jun 24 20:56:48 2024 xxxxxx: TLS: Initial packet from [AF_INET]x.x.x.x.x.x., sid=xxxxx xxxxx
Mon Jun 24 20:56:48 2024 xxxxxx: VERIFY OK: depth=1, CN=xxxxxxx
Mon Jun 24 20:56:48 2024 xxxxxx: VERIFY KU OK
Mon Jun 24 20:56:48 2024 xxxxxx: Validating certificate extended key usage
Mon Jun 24 20:56:48 2024 xxxxxx: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Mon Jun 24 20:56:48 2024 xxxxxx: VERIFY EKU OK
Mon Jun 24 20:56:48 2024 xxxxxx: VERIFY OK: depth=0, CN=xxxxxxxx
Mon Jun 24 20:56:49 2024 xxxxxx: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 384 bit EC, curve secp384r1, signature: ecdsa-with-SHA512
Mon Jun 24 20:56:49 2024 xxxxxx: [vpn-2024] Peer Connection Initiated with [AF_INET]xxxxxxxxx
Mon Jun 24 20:56:50 2024 xxxxxx: SENT CONTROL [xxxxxx]: 'PUSH_REQUEST' (status=1)
Mon Jun 24 20:56:50 2024 xxxxxx: PUSH: Received control message: 'PUSH_REPLY,route-gateway xxxxxxx,topology subnet,ping 40,ping-restart 100,ifconfig xxxxxxxxxxxxx,peer-id 32,cipher AES-256-GCM'
Mon Jun 24 20:56:50 2024 xxxxxx: OPTIONS IMPORT: timers and/or timeouts modified
Mon Jun 24 20:56:50 2024 xxxxxx: OPTIONS IMPORT: --ifconfig/up options modified
Mon Jun 24 20:56:50 2024 xxxxxx: OPTIONS IMPORT: route-related options modified
Mon Jun 24 20:56:50 2024 xxxxxx: OPTIONS IMPORT: peer-id set
Mon Jun 24 20:56:50 2024 xxxxxx: OPTIONS IMPORT: adjusting link_mtu to 1624
Mon Jun 24 20:56:50 2024 xxxxxx: OPTIONS IMPORT: data channel crypto options modified
Mon Jun 24 20:56:50 2024 xxxxxx: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Mon Jun 24 20:56:50 2024 xxxxxx: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Mon Jun 24 20:56:50 2024 xxxxxx: TUN/TAP device tun_c_xxx opened
Mon Jun 24 20:56:50 2024 xxxxxx: net_iface_mtu_set: mtu 1500 for tun_c_xxx
Mon Jun 24 20:56:50 2024 xxxxxx: net_iface_up: set tun_c_xxx up
Mon Jun 24 20:56:50 2024 xxxxxx: net_addr_v4_add: xxxxxxxxx dev tun_c_xxx
Mon Jun 24 20:56:50 2024 xxxxxx: /etc/openvpn/updown.sh tun_c_xxx 1500 1624 xxxxxxxxxxxxx init
Mon Jun 24 20:56:51 2024 xxxxxx: Initialization Sequence Completed
This topic was automatically closed after 18 days. New replies are no longer allowed.
