Rut950 OpenVPN Cannot pre-load keyfile
I’m trying to replicate a OpenVPN connection in a RUT950. I have a OpenVPN profile that connects fine with the OpenVPN client, but I cannot get my router to connect.
From the log:
compressed unless “allow-compression yes” is also set.
Mon Mar 11 16:14:49 2024 daemon.warn openvpn(AMP)[26197]: Multiple --down scripts defined. The previously configured script is overridden.
Mon Mar 11 16:14:49 2024 daemon.warn openvpn(AMP)[26197]: Multiple --up scripts defined. The previously configured script is overridden.
Mon Mar 11 16:14:49 2024 daemon.err openvpn(AMP)[26197]: Cannot pre-load keyfile (vpn-2024-tls.key)
Mon Mar 11 16:14:49 2024 daemon.notice openvpn(AMP)[26197]: Exiting due to fatal error
Do I need to manually copy the “vpn-2024-tls.key” into the router? if so what location? etc/openvpn?
I have four files:
ca.crt
My.crt
Two keys:
vpn-2024-tls.key
My.key
OpenVPN Config file:
client
dev tun
proto udp
remote 123.456.789.123
port 62457
resolv-retry infinite
nobind
persist-key
persist-tun
keepalive 10 60
comp-lzo
ca ca.crt
cert my.crt
key my.key
remote-cert-tls server
verb 3
cipher AES-256-GCM
auth SHA512
tls-ciphersuites TLS_AES_256_GCM_SHA384
tls-crypt vpn-2024-tls.key
auth-retry nointeract
I’ve tried a few different combinations in the OpenVPN Client configuration, but I get the same errors.
Any tips please?
Cheers M
Any help here please?
Cheers M
