+CMS ERROR: 500
RUT9XX_R_00.06.09.5
I am trying to forward sms but get the above error if I try to send.
SIM is fine and valid for sms.
+CMS ERROR: 500
RUT9XX_R_00.06.09.5
This CMS error indicates that the modem was not able to deliver the message. A few possible causes could be:
The mobile plan does not support sending the SMS;
The router is not registered on the network;
The phone number you are trying to send the message to is invalid or you’re using an incorrect format;
I’d recommend updating to the latest firmware if your device supports it, checking if you can send SMS from your phone using this SIM, setting the device to 3G or 2G-only and checking if the issue reappears, or using a different SIM.
