RUT906 VPN compression, encoding failure / RMS expired
RUT906 L2TP VPN worked well with compression/encoding enabled (default) on the receiver side…
until RMS coverage expired…
since then (1-2 hours later), l2tp vpn only works without compression and encoding…
RUT906 is behind Vodafone network, maybe vodafone has just disabled these protocols and its a coincidence… but i dont think so
the receiver side mikrotik says
CCP lost compression got out of sync: disabling compression
Encryption got out of sync - disabling
Does RUT906 encrypted VPN work only with RMS credits topped up?
Doest that work without encryption if credits expired?
thanks
Bozso
