RUT901 unstable rms/vpn
Using VPN aprx every 15-20 second we have connection lose, reconnecting.
Ethernet is stable, problem only in VPN.
It is possible fix?
Can you provide more information / screenshots regarding your RMS VPN configuration?
Make sure that you choose the RMS VPN Location close to the area of the device to make sure that there will be less latency.
Check as well if you’re having a stable internet connection since this might be a factor on why the VPN keeps disconnecting.
-Mike
