RUT901 SMS utilities Modbus custom script
Hi, i would like help with using SMS utilities with SMS rules, use custom script.
How can i make it send SMS like “Power: 100kW, voltage: 400V” ?
if i use CLI i get:
root@RUT901:~# ubus call modbus_client tcp.test '{"ip":"192.168.1.251", "port":"502", "id":1, "timeout":1, "function":3, "first_reg":1, "reg_count":"2", "
data_type":"16bit_int_hi_first", "no_brackets":1}'
        "error": 0,
        "result": "100,0"
Sms is like:
"v?error":0
"result: "100"
Status code: 0"
Also, can i make this script run as Modbus client Event (from PLC request) or at a set time, for example midnight?
Thank you.
Hi Mskrepsky,
You can refer to this file as a guide for your script.
script.zip (383 Bytes)
Basically, this script uses the jsonfilter command to only pull out the value of “result”.
If you want to run this script at a set time, you can use crontabs. More information HERE. Example (0 0 * * * /path/to/your/script.sh)
Let me know if this helps.
